no crank
96,385 MILES • 4.7L • V8 • 4WD • AUTOMATIC
ACWCONFUSED
no power from key switch. also shifter moves without using brake pedal. no shifter indicator lights.
Aug 28, 2017 at 12:02 PM
STEVE W.
  • 15,418 POSTS
Check fuse #8 (10amp) in the power center under the hood for the shift interlock.
No power from key as in you turn it and get no dash lights or anything? Or do those come on but the engine doesn't turn over?
Check fuse 5 (40 amp) in the power center for the loss of power at the key.
Aug 29, 2017 at 3:56 PM
