Not cranking over
2002 ISUZU RODEO
215,000 MILES • 3.2L • V6 • 4WD • AUTOMATIC
JONCARN
Turn the key and no crank. I have pulled the starter and it tested good, battery has been load tested and good, checked all fuses and swapped relays around with known working relays. Replaced the neutral safety switch, which is also the gear position indicator. I did notice the gear position lights in the dash are not lighting up when the key is in the run position like usual. When I plugged my scan tool in the gear position lights come on and I can hear the starter solenoid click when I try to start. Car has an alarm and I have set the alarm with the fob, unlocked and no change. Locked and unlocked by key and no change. When the scan tool is not plugged in and I turn the key to run I can also hear the vacuum switch on the engine by the fuel pressure regulator rattling fast. This stops too when I plug in the scan tool. The scan tool cannot read the ECM either. The only driving issue I have had recently is the fuel level gauge stops working when I fill up, it starts working when I get under 3/4 full, code P0435 I believe. Fuel pump was replaced about a year ago.
Feb 20, 2017 at 9:16 PM
  • 55,423 POSTS
Hey JONCARN,
It sounds like you might have an engine that is locked up, put a large socket on the front of the engine to see if it turns, next remove all of the spark plugs to see if it turns, it might have a blown head gasket.
here is a guide that will also help you
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Feb 23, 2017 at 7:12 AM
JONCARN
I have already checked and the engine rotates normally. Plenty of oil too. It seems like I have a power leak but I just can't find it. I pulled the starter again and cleaned the grounding surfaces but nothing. I am getting 12v at the starter, and at all primary leads from the battery. Checked all the grounding points I could reach and all are secure. After I pulled the starter I was able to get my scan tool to communicate with the ECM, so it appears to be working. I am going to check the ignition switch tonight
Feb 23, 2017 at 7:19 AM
  • 55,423 POSTS
Is the starter getting a trigger signal?
Feb 23, 2017 at 7:26 AM
JONCARN
Got it fixed. Ended up being the ground wire. It melted against the edge of the block. Just happened to see it spark.
Feb 23, 2017 at 11:23 AM
  • 55,423 POSTS
Glad you could get it fixed please use 2CarPros.com anytime we are here to help
Best, Ken
Feb 24, 2017 at 2:59 AM
