when i try to start nothing happens, no crank with key. when i checked the relays press on starter relays it crank but doesn't start.
Jan 26, 2022 at 5:02 AM
✓Experienced Mechanic
Remove the starter relay and inspect the pins it connects to. Check them to make sure there is no corrosion on them. Also, make sure they haven't been pushed lower into the fuse box causing a poor connection.
Based on your description, it sounds like it simply has a faulty connection.
Let me know what you find.
Jan 26, 2022 at 9:40 AM
JEAN COAKLEY
MEMBER
PCM ground wire was loose plus fuse no 8 PCM fuse was blown.
Feb 18, 2022 at 9:13 AM
Thanks for the update. I'm glad to hear it has been repaired. I had a feeling it was a connection issue. LOL
Please feel free to come back anytime in the future if you have questions. You are always welcome here.
