No crank
1990 GMC S15
106,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
ERIC30
  • 6 POSTS
It runs and drives fine. After driving for about thirty minutes or more it will not start. It will not even crank, but dash lights and radio work. It will start again after sitting for about twenty minutes or so. Thought it was ignition control module so I replaced, but same problem. Cap, rotor, plugs and wires new less than 2,000 miles ago, alternator and battery less than 5,000 miles ago. New AC/Delco fuel pump and fuel filter less than 12,000 miles ago.
Jul 4, 2017 at 12:59 PM
HMAC300
  • 48,601 POSTS
check battery for condition including load test most places do for free. then check for a starter draw may be drawing to many apmps. also check engine/battery ground.
Jul 4, 2017 at 11:55 PM
RENEE L
  • 1,260 POSTS
Hi ERIC30,
Here is a link to helpful information from this site that features written instructions, pictures and a video explaining how to load test your battery yourself. If you need further assistance please come back to 2CarPros.com. We are always happy to help.
https://www.2carpros.com/articles/how-to-check-a-car-battery
Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
Jul 5, 2017 at 2:06 AM
ERIC30
  • 6 POSTS
Battery tested good, cables looked good, took starter to parts store and it tested bad. Replaced, but haven't driven far enough to get hot yet.
Jul 6, 2017 at 7:38 AM
  • 55,412 POSTS
Cheers, Ken
Jul 7, 2017 at 7:50 AM
