No crank bench test old starter was good?
201,000 MILES • 3.6L • 4WD • AUTOMATIC
FRANKC05
Replaced starter after no crank. Bench test old starter it was good. Still same issue. tested relay that’s good. Tested pin 87 an 30 that tested good. Jump starter it was clicked a few time now nothing. Have 12.8 volts at main power lug on starter. Any thought will be helpful thanks.
Nov 23, 2026 at 3:14 PM
MECHTRIX
  • 599 POSTS
Eng body ground could be bad also batery ground and id say check those first and let us know
Nov 23, 2026 at 4:18 PM
MECHTRIX
  • 599 POSTS
Side note "
This vehicle has 3 main grounds and a few smaller grounds the main one that can cuase a no crank situation is usually the ground strap on the passenger side wheel well ti engine ..it one of the braided style grounds that it notorious for corrosion and just plain braking and falling right off id check that fir then the one under th passenger seat batery ground cabke then the ground cable juntiin on the fire wall then the ground ti the power distrebution modual on the drivers side to the fender well good luck hope this helps
Nov 23, 2026 at 4:32 PM
MECHTRIX
  • 599 POSTS
But my honest best guess would be the braided engine ground the passenger side..
Oh and also check the exhuast ground strap to body that one corrodes pretty fast too being the braided type theres more surface for water and road scum to cling to it makes it corrode pretty fast
Good luck
Nov 23, 2026 at 4:39 PM
  • 55,781 POSTS
Are you getting power to the starter trigger wire when the key is in the crank position? This video can help us.
https://www.youtube.com/watch?v=6YRW8fyNudY&t
Please upload a short video of what is happening.
Nov 23, 2026 at 6:22 PM
MECHTRIX
  • 599 POSTS
Yep like strailer said that circuits important too".. and after you check the grounds if its still not working
if its a manual transmission you might want to check the clutch start switch ..but if its an automatic try it in neutral instead of park if it starts in neutral then the park switch might be going hope this helps good luck
Nov 23, 2026 at 9:15 PM
