No crank
213,221 MILES • 6 CYL • 2WD • AUTOMATIC
SUEANNERNST22
Truck won't crank. When you turn the key over dash lights come on and battery is good. It just won't crank.
Mar 9, 2020 at 6:14 AM
Good afternoon,
What is the battery voltage? You need 12.4 to 12.6 volts.
I attached a wiring diagram for you. Do you have a test light or voltmeter to do some testing?
Mar 9, 2020 at 7:12 AM
