No cran no start
RAQDADDY
  • 1990 PONTIAC SUNBIRD
  • 110,000 MILES
My cae died a while ago. I took the wife to work in it and then it went back out later and nothing happened. No crank no start. Found that the starter solenoid housing was crack and replace it and both my battery cables as well. Still nothing. Light come on on the dash and all of the fuses appear to be good. Found that I had no power on the trickle wire and replaced the ignition switch. Starting to pull my hair out please help
Monday, April 29th, 2013 AT 3:57 PM
HMAC300
  • 48,601 POSTS
Check battery condition including load test then check to see if going through ign switch neutral safety to starter check purple wire on starter solenoid if power there when try ing to start and is 12 volt then starter is problem.
Tuesday, April 30th, 2013 AT 6:35 AM
Related Engine Not Running Content
