No compression in two cylinder
125,000 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
FULLCLIP0417
Can it be fix or I need a new engine?
Oct 8, 2019 at 1:06 AM
AL514
  • 5,700 POSTS
Hello thanks for using 2CarPros. It is possible to repair top end components. Such as intake valve, exhaust valves. The cylinder head will have to be removed to replace any in-cylinder components. Doing a cylinder leakage test will tell you which valve is not seating right.
Oct 8, 2019 at 7:16 AM
