No compression
143,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
CHNAPPI52
Have minimum compression in most cylinders (110 to 130psi). So why are cylinders six and eight showing no compression? I have good idle and steady vacuum.
Oct 8, 2018 at 2:07 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
If six and eight are right next to each other a blown head gasket between the two cylinders could be why there is no compression in each cylinder.
Oct 8, 2018 at 3:40 AM
CHNAPPI52
I tried the leak down test 0 psi. I used pressure on each cylinder. Is it possible the right bank is weak? I have 0 pressure on 2,4,6,8!
Oct 8, 2018 at 7:59 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You have zero compression on 2468?
I think you are doing something wrong with these tests. Impossible that you have a good idle or even a running engine with no compression on 2468.
Oct 8, 2018 at 8:44 AM
