No communication with ecu or pcm
190,345 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
FRYAR RYDA
A week ago i got cut off had to slam on my brakes, car died no check engine light even if i turn the switch to accessory. No fuel fire or injector pulse and my scan tool cannot communicate with the PCM or ECU anyone having these problems? please help. i have a newborn and no other form of transportation and need help bad. base model with an automatic transmission.
Sep 12, 2016 at 1:28 AM
  • 55,673 POSTS
It sounds like you had a wiring short circuit, please check all fuses and check the connections at the battery here is a guide to help you
Please let us know what you find so it will help others.
Best, Ken
Sep 15, 2016 at 5:37 AM
