No communication to the scan tool?
200,000 MILES • 6.8L • V10 • 2WD • AUTOMATIC
EARL91
  • 88 POSTS
no communication to the scan tool. i have power to the obd2 port, just no communication to the scan tool. i cant find any info to help on the inter web.
Dec 10, 2023 at 10:43 PM
  • 55,770 POSTS
Did you try the scanner in another car to see if it works?
This video can help as well:
https://youtu.be/6Tlg3JmgNSQ?si=GyIBIQSRKZNomZks
You should check the grounds (2) of the connector as well, here is a guide to help and the OBD2 port wiring diagrams so you can see how it works and which wires to test. Test the black and blk/wht wires for ground. Check out the images (below). Let us know how it goes.
Dec 12, 2023 at 4:03 AM
  • 55,770 POSTS
anything?
May 9, 2024 at 4:59 AM
