no cold air coming from the A/C?
300,000 MILES • 1.9L • 4 CYL • TURBO • 2WD • AUTOMATIC
MURIELLE DESJARDINS
Air conditioning clutch not engaging.
Jul 17, 2022 at 10:44 PM
  • 55,746 POSTS
The clutch will not engage if the system is low on refrigerant so let's do a check using a simple recharge unit from the local parts store. Here is a video that will help with a guide, and I have included an Amazon link to the set up you need.
https://youtu.be/uZrQCGwXfek
This will tell you how much is in the system, if none you will need to do a leak test, this guide will help.
https://www.2carpros.com/articles/air-conditioner-leak-detection
Here is what you need:
https://amzn.to/3cpo4eD
Check out this guide as well:
Jul 18, 2022 at 3:40 AM
