A/C not blowing cold air
117,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
MARK BENTON
Fan works, blows air but no cold air. Heater works fine. Was assured that previous owner would have added Freon if that were the problem. What is most likely culprit? Bad compressor or needs recharge of Freon?
Aug 29, 2018 at 12:13 AM
Good morning.
The first step is to get a set of gauges and see what the pressures are for the Freon system.
Do you have a set of gauges to check the system? If not, you can rent a set at a parts store.
Does the compressor engage when you turn on the AC?
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Aug 29, 2018 at 12:31 AM
