Have no spark coming out of a brand new coil. what can cause this to happen?
Sep 9, 2017 at 8:42 AM
CJ MEDEVAC
✓Experienced Mechanic
Using a voltmeter, what is the voltage to the positive side of the coil with the key in the "on" position?
Is there any kind of history that may have influenced this problem?
The Medic
Image (Click to enlarge)
Sep 9, 2017 at 10:20 AM
OLDFORDDOG
MEMBER
I did test the positive side with my meter and had voltage there. I read that both wires to coil should have power when key is on, so I am unclear about that. should the negative side have voltage or no voltage when key is on?
Thank you!
Sep 11, 2017 at 3:39 AM
CJ MEDEVAC
Why did we install the new coil?
The Medic
Sep 11, 2017 at 8:16 AM
CJ MEDEVAC
Without digging for anymore information right now.
This would be my first guess to a sudden engine death and then discovering spark is not present. Like I said, best guess without further testing. See link below:
