No codes on scanner Engine will miss?
2000 FORD E-SERIES VAN
147,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
JIMMY MCQUEEN
Engine will miss while idling and after warmup it falls on its face when I accelerate. There is a service engine soon light on but there are no codes when scanned. The service engine light started blinking when I was pulling a loaded trailer. Oh, and it smelled like a tailpipe was in the cab.
Thanks.
Mar 31, 2026 at 12:21 PM
  • 55,433 POSTS
First, does the engine have an exhaust leak? Also, I would change out the fuel filter which is on the frame rail. Here is a video to help you.
https://www.youtube.com/watch?v=Boi0DPXVHbM
If the check engine light is blinking there should be codes unless the PCM is bad. Can you please upload a short video of the engine idling so I can see? We should do a compression test, and replace the spark plugs and possible the ignition coils. We need to see if you have a good engine. Also, please give me a short video of the engine cranking, I can tell if the engine is any good from that as well. Ken
Apr 1, 2026 at 2:52 AM
