ABS light on after replacing front and rear wheel bearings
181,234 MILES • 3.8L • V6 • 2WD • AUTOMATIC
DAVID-86
No ABS before I changed all the brakes and front wheel bearings and now I have an ABS light on. I tried pulling the codes and don't have any codes detected.
Nov 26, 2019 at 1:16 AM
Good afternoon,
What kind of scan tool do you have? Some or most code readers do not read ABS codes.
Recheck your work in the front. If you did not have a code prior to this repair and you now have the issue, it is related to your work. Make sure the sensors connectors are clean and tight.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Mar 29, 2021 at 2:25 AM
