Hello, recently experiencing a jerking and sometimes engine sputters and shuts off. 14 months ago, a new Standard Motors coil was installed as well as new HQ Taylor wires and Bosch Platinum plugs. Also a new ACDELCO spider injector assembly and fuel filter. Two years ago, the fuel pump failed and a new Spectra Premium Tank with factory fitted pump was installed. Things going good until I have recently hit several large pot holes causing some slamming? No apparent damage as mechanics can see.
My question after watching your Oct 13, 2018 video is, Can a single coil feeding a distributor give intermittent operation and thus cause intermittent misfire?
Thanks, Tony
PS. I do have a BlueDriver OBD2 scanner. I did have a O2 sensor failing and so last Friday, I had all four replaced. Codes were cleared and have not returned. The above problem is just like as you mentioned in the video.
Thanks, Tony
Jun 3, 2020 at 12:18 PM
