No clutch pedal pressure
1992 NISSAN TRUCK
176,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
TERRENCE FISHY BASS
So my clutch pedal went to the floor. I did some research found out it was probably either the slave cylinder or master cylinder. Well I replace both and dropped the transmission to replace the clutch kit. After doing all that I still have no clutch pressure. Bled the master and the slave cylinder still nothing. I cannot figure this out.
Jun 3, 2018 at 3:20 PM
KHLOW2008
  • 41,814 POSTS
Hi Terrence,
While bleeding the system, when the bleeder bolt was loosened, is hydraulic fluid shooting out strongly with pressure?
When clutch pedal is depressed and released a few times in succession, are there any movement of the clutch fork?
When transmission was dropped, was the clutch system checked and working components found to be in good condition, items such as clutch pressure plate, bearing and clutch fork?
How did you bleed the system?
K H Low
Jun 4, 2018 at 2:13 PM
