No clock/radio will not function after car was serviced.
150,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
COLINENGSTROM
I recently in a car accident. I was rear ended and had to get a new bumper put on. When my Mazda was towed to the shop the radio worked. When I picked it up it does not. I get nothing, no display no time nothing. I pulled and replaced the 2 fuses in the fuse panel by the hood release and that did nothing. I have read the manual back to front and there is no mention of a security code. I have the factory installed 6 disc CD changer. Any ideas?
Mar 29, 2014 at 9:46 AM
  • 75,988 POSTS
You sure the clock and the radio are in the same circuit together -double check the fuses-could be a security code issue
Mar 29, 2014 at 11:07 AM
COLINENGSTROM
According to the manual they are on the same fuse there is a second one for the rest of the audio system ie. Amp and such. How would I know if I need a security code? The manual does not mention a security code although I bought it used so there may be a missing one. But even it there was how could I enter it with no display?
Mar 29, 2014 at 11:59 AM
