Doesn't show the check engine with the key on, and it wont start or crank, shows code Po650 and U2501
Jul 9, 2014 at 3:48 AM
HMAC300
✓Experienced Mechanic
the 0650is a mil light malfunction and have a pro check this try resetting your anti theft for the no start. see pic
Image (Click to enlarge)
Dec 16, 2018 at 1:41 AM
JESUSJ
MEMBER
I just reprogram the key, and got rid of the code P0650 but still have the U2105 loss comm With The Engine Control System - With Automatic Transmission
HMAC300
that is a can problem and a pro should check this if he does he has to freeze frame it and record it prior to clearing the code. this can be a short to ground broken wire, short between ecm and tcm open circuit etc. or shorted together. definitely to be looked at by apro
