Doesn't show the check engine with the key on, and it wont start or crank, shows code Po650 and U2501
Wednesday, July 9th, 2014 AT 10:48 AM
HMAC300
MECHANIC
The 0650is a mil light malfunction and have a pro check this try resetting your anti theft for the no start. See pic
Image (Click to make bigger)
SPONSORED LINKS
Sunday, December 16th, 2018 AT 9:41 AM
JESUSJ
MEMBER
I just reprogram the key, and got rid of the code P0650 but still have the U2105 loss comm With The Engine Control System - With Automatic Transmission
HMAC300
MECHANIC
That is a can problem and a pro should check this if he does he has to freeze frame it and record it prior to clearing the code. This can be a short to ground broken wire, short between ecm and tcm open circuit etc. Or shorted together. Definitely to be looked at by apro
