Hi, I had some codes read prior to the purchase of this car. All cylinders showed a misfire, and a code for multiple misfire as well. The codes are P0300, P0301, P0302, P0303, P0304, P0305, and P0306. I also have a SRS light on as well and see it could be a number of things from researching. For the price of the car was a steal, but I want to make sure I am not over my head in price to fix it. The codes show it can be ignition coil, spark plug, EGR valve, fuel pressure regulator, or fuel injectors. Now the car idles fine, I highly doubt all fuel injectors are bad or the coils out at the same time. I have yet to do any digging in the engine yet, due to more focused on the title transfer and getting all that sorted out first. It has an aftermarket exhaust and intake on it just for further information. Is there a way to deactivate the check engine light or a possible blown fuse or light in the dash that may be the reason for no check engine light coming on? What would be the best route of checking things first and then so on? I will add pictures to the post for response answers-questions if that is possible after posting.
Thank you and ask away I am ready to get my hands dirty working on this issue.
Oct 19, 2017 at 11:50 AM
