Engine cranks but does not start and there is no check engine light
150,000 MILES • 4.0L • V8 • 2WD • AUTOMATIC
CURTIS ZINK
Cranks but won't start. has no spark from the coil, no injector pulse and no check engine light.
Mar 4, 2021 at 2:28 PM
  • 110,248 POSTS
If you aren't getting spark or an RPM signal, it sounds like the crankshaft position sensor has failed.
Take a look through this link:
This is where I would start. Here are directions for replacement. The pics below correlate with the directions.
________________________
1991 Lexus LS 400 V8-4.0L (1UZ-FE)
Procedures
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Crankshaft Position Sensor Service and Repair Procedures
PROCEDURES
PROCEDURE
Removal
1. Disconnect negative terminal cable from battery.
CAUTION: Work must be started after 90 seconds from the time the ignition switch is turned to the LOCK position and the negative (-) terminal cable is disconnected from the battery.
2. Remove engine under cover.
3. Disconnect crankshaft position sensor connector.
pic 1
4. Remove the bolt and crankshaft position sensor.
Installation
pic 2
1. Install the crankshaft position sensor with the bolt.
Torque: 6.4 N.m (56 in.lb.)
2. Connect crankshaft position sensor connector.
3. Install engine under cover.
4. Connect negative terminal cable to battery.
____________________________________
Take care and God Bless,
Mar 5, 2021 at 3:43 PM
