No bus, code p3040 bank a sensor
198,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
EDDIE BLAKE
I bought this car and drove it down the street. it shut off and my code reader said p3040 sensor bank a. so I replaced the cam shaft sensor, I also had to replace the fuse for the dash. after that it now says no bus and when I try to start it it says no bus and kind of sounds like the battery is going bad. the fuel gauge also bounces up and down. I tried to jump it but didn't start I checked the fuses and they were good.
Sep 22, 2020 at 12:40 PM
  • 110,248 POSTS
Can you recheck the code? Do you mean P0340?
If it's a P0340, that indicates no cam signal at the PCM. Here are diagnostics for that code:
_______________________________
The attached pics are the actual diagnostics.
1998 Plymouth Breeze L4-2.0L VIN C
TC-1A No Cam Signal at PCM
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection Manufacturer Code Charts Trouble Code (TC) Tests TC-1A No Cam Signal at PCM
TC-1A NO CAM SIGNAL AT PCM
Related Image
Pic 1
Diagnostic Chart
pic 2
Related Image
pic 3
Diagnostic Chart
pic 4
Let me know if that is the code and if this helps.
Sep 23, 2020 at 10:27 AM
Couple things. Do I understand it correctly that the P0340 is no longer there?
We need to start with load testing the battery as if this is drained it will cause all sorts of crazy issues.
Then we need to replace it if needed then check for codes again.
The no BUS message means the PCM cannot communicate with other modules so it puts this message up.
Let me know what happens with this and we can go from there.
EDDIE BLAKE
Changed battery no BUS went away, but still won't start. doesn't sound like the starter. it had old gas in it but l had been bleeding it from the line and I think I got it all out. it sounds like it wants to start but something isn't happening.
Sep 23, 2020 at 11:00 AM
  • 110,248 POSTS
Do me a favor. Record it cranking so I can hear what it's doing. Also, see if it starts with starting fluid.
Sep 23, 2020 at 11:35 AM
EDDIE BLAKE
Okay.
Sep 23, 2020 at 12:09 PM
Hearing it will help so that is a good idea. Also, if you had old fuel, you may want to change out the plugs as old fuel will foul the plugs and cause it to not start and act like it wants to start but not catch.
Sep 23, 2020 at 12:42 PM
EDDIE BLAKE
That's what it's doing.
Sep 23, 2020 at 9:05 PM
  • 110,248 POSTS
Not sure what you mean. Is it trying to start as KaseKenny mentioned? Also, have you tried starting fluid?
Sep 24, 2020 at 11:27 AM
