Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Sunbird
Brakes
Pedal
no brakes when i apply brake pedal
1992 PONTIAC SUNBIRD
143,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
DEBBIE GILLIT
MEMBER
1 POST
master cylinder is full but I hear a swooshing sound when I apply the brake pedal. Pedal goes all the way to the floor.
Aug 10, 2017 at 1:36 AM
CJ MEDEVAC
Experienced Mechanic
Every thing was fine prior to this?
Did you run out of fluid?
If my 1st question received a 'yes', w/ no fluid having been lost,
Mr. Master Cylinder's piston/ plunger seal may have tore/ wore out and it can no longer 'push' fluid, it's allowing it to pass on by the seal.
The Medic
Aug 10, 2017 at 9:21 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
