No brakes, no pressure in my brake pedal?
160,000 MILES • 4.0L • V6 • AUTOMATIC
HECTOR 23
Changed master cylinder. Power brake booster and driver side caliper. Did all 4 brakes the bleeding and also the master. And still no brakes.
Aug 21, 2022 at 2:54 PM
  • 55,658 POSTS
Yep, this is because you have air trapped inside the ABS controller, which is common, this video will show you how to open the ABS valves and then bleed the system normally.
https://youtu.be/nQRnKyVyMuQ
and
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Aug 22, 2022 at 5:40 AM
