Brakes do not work after replacing inner and outer tie rod ends
144,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
BARRY CLEMENTS
My brakes worked just fine. today i replaced my inner and outer tie rod ends now my brakes do not work. there is no pedal play, yet no brakes either! can you help me?
Jan 26, 2019 at 9:35 AM
Good evening,
No brakes could be a fluid leak from the repair, failed master cylinder or low fluid.
You need to check the system for leaks. Go over the work performed to see if there was something broken.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Jan 26, 2019 at 9:43 AM
BARRY CLEMENTS
did not find any leaks.Master cylinder was fine when driven yesterday. not low on fluid. actually, it appears some fluid was forced back out of reservoir. Can this happen?
Jan 26, 2019 at 12:33 PM
Did you remove the calipers during the repair? That would explain why the fluid was pushed back into the cylinder.
Jan 26, 2019 at 8:09 PM
BARRY CLEMENTS
i didnt reconnect pressure hose from m/c! all is good.thank you very much!
Jan 27, 2019 at 5:07 AM
Your welcome.
Glad you got it fixed.
Always glad to help
Jan 27, 2019 at 5:26 AM
BARRY CLEMENTS
again.thank you.car was down 3 weeks.back on the road.good feeling.have a great day!
Jan 27, 2019 at 10:41 AM
You as well.
Your welcome
Jan 27, 2019 at 10:44 AM
