Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Pathfinder
Brakes
Hose (Flex)
Replace/Remove
My brake flex hose is worn I need to replace it
2003 NISSAN PATHFINDER
200,000 MILES
CANDISE STOUT PEARSON
MEMBER
1 POST
No brakes after changing rear brakes I found the rear brake hose is leaking.
Feb 21, 2018 at 3:12 AM
Experienced Mechanic
I am attaching the info from the manual on how to do this. However, you will need to bleed the brakes so here is a guide that will help with this:
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Below is the process from the manual. Let us know if you have other questions. Thanks
Images (Click to enlarge)
May 8, 2021 at 11:54 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine has low power
