Bled front and I still have nothing?
130,000 MILES • 3.4L • 6 CYL • AUTOMATIC
TLSTEELE 296
  • 8 POSTS
I got the car from a friend at work she stated that it needs new brake pads. The shop she took it to said the lines were in bad shape we live in Iowa so the under carriage was all rusted the rear drum brakes were so bad I chose to delete them completely. I then replaced the lines from abs to calipers in front,capped off the ones to rear. Bled front and I still have nothing I don't have a lot of money but it's my only vehicle I need these brake to work. Help?
Aug 23, 2025 at 3:54 PM
  • 55,628 POSTS
The only way to get a good brake pedal is to have both front and rear working, there is a load balancer inside the brake master. Also, how did you block the line for the rear? you may have air stuck in the ABS controller, the valves need to be opened when bleeding to get the air out. Please go over this guide
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
This will go over the reasons the brake pedal can be low.
Aug 24, 2025 at 5:55 AM
TLSTEELE 296
  • 8 POSTS
I totally removed the rear brake lines, they were , leaking all over everytime I replaced a section they would leak sowe where else.. I have almost no money and couldn't put everything on the rear that they would have needed everything . After I removed the lines i capped the spot on abs mod where they originated. Then I pulled fuse on ABS.
Aug 26, 2025 at 6:35 PM
  • 55,628 POSTS
Yep, chances are air is trapped inside the ABS unit.
Aug 27, 2025 at 1:15 AM
TLSTEELE 296
  • 8 POSTS
Ok so I noticed yesterday that none of that abs wiring is plugged in and as I said I pulled tbe fuse myself. I'm putting in a new master cylinder cause it's leaking on the back side. Is there any way to bleed that abs module without a scanner?
Aug 28, 2025 at 10:02 PM
  • 55,628 POSTS
Not really, you need the scanner to open the valves. This video will help
https://www.youtube.com/watch?v=nQRnKyVyMuQ
I would go over the guide again as well. Let us know how it goes
Aug 29, 2025 at 9:15 AM
