No brake pressure after replacing the power brake actuator?
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
LOCHOW2021
I asked a mechanic to help replace the power brake actuator, but he told me the brake doesn't work even after the bleedings. And he told me a scan tool is required to make it work. He asked me to bring the car to the dealer to reset it because he doesn't have the scan tool. Is a scan tool a must? I saw some videos saying no scan tool is required. Does anyone here know what to do?
Sep 27, 2022 at 1:56 AM
  • 55,647 POSTS
Yes, so what happens is air gets trapped inside the ABS controller and the only way to remove it is to connect a scanner and open the ABS valves while bleeding the system.
Check out this video which shows you how the job is done:
https://youtu.be/nQRnKyVyMuQ
Sep 27, 2022 at 4:44 AM
