No brake pedal
90,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
HENRY DAVIS
I changed; master cylinder, all four calipers, bled system, but no brake pedal.
May 6, 2018 at 3:14 PM
HARRY P
  • 2,292 POSTS
Did you bleed the master cylinder before installing it? If not, then you will need to take it off and do it, reinstall it, and then re-bleed the calipers. Look at step three in this guide:
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Good luck and let us know.
Mar 10, 2021 at 3:01 AM
