No brake pedal?
100,450 MILES • 4.6L • V8 • 2WD • AUTOMATIC
JLGADAMS
I replaced the rotors, calipers, pads, and master cylinder even the parking brake shoes. I had the brakes bleed. The brake pedal still goes to the floor. I had good brakes before I replaced anything. I smelled burning brakes in the back of the car. So I was just going to replace everything. Now no brake pedal.
May 17, 2023 at 11:52 PM
  • 55,636 POSTS
So, it sounds like you have air stuck in the ABS unit which is common, and you need to have a scanner open the valve while you bleed the brakes. Please check these two guides out to help us fix the problem.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Please go over these guides and get back to us.
May 18, 2023 at 5:32 AM
