Turn signal and brake lights are not working?
180,000 MILES • 2.9L • V6 • 4WD • MANUAL
CHIEFAUTOPARTS
The Hazard flashers do work. replaced the multi-function switch already checked the fuses as well. Any suggestions or direction of where to go next is greatly appreciated.
Jul 11, 2023 at 9:34 AM
  • 110,248 POSTS
Because of the model year, I wasn't able to find a great wiring schematic, but I did find the original factor schematics. I attached it below for you so that you have a reference.
There are two fuses that aren't making much sense to me right now. One powers the signal flasher and the other is for the hazard lights. I need you to check both fuses. In addition to checking the fuses, make sure there is power present at the fuse site.
I'm a bit confused because the brake light switch gets power from the flasher circuit but then runs to the multi-function switch.
In addition to checking the fuses, I need you to check the light green wire with a red tracer at the brake lamp switch for power. It should have battery voltage at all times. If that wire is good, then I need you to depress the brake pedal and see if there is power out from the switch via the light green wire.
Try this and let me know the results.
Jul 11, 2023 at 1:37 PM
