No brake lights
1995 CHEVROLET ASTRO
35,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
RED20
Hazards, turn signals and running lights work. no brake lights, no blown fuse.
Jan 29, 2018 at 5:29 AM
CARADIODOC
  • 34,369 POSTS
Start at the brake light switch above the brake pedal. Check for twelve volts on the orange wire. If you have that, check for twelve volts on the white wire. That one should only be there when you press the brake pedal.
Jan 29, 2018 at 5:36 AM
