Brake lights are not working?
100,000 MILES • 2.2L • 4 CYL • TURBO • 2WD • MANUAL
SNSJSJ
Not the fuse. Not the bulbs. Not the brake switch.
Oct 8, 2023 at 4:06 AM
  • 110,248 POSTS
If the things you mentioned are good and functional, then either you have a broken wire or no ground.
This vehicle isn't offered in the US, so I don't have any wiring schematics to check. However, have you confirmed there is continuity to ground from the light assemblies?
Also, did this happen all at once?
Oct 8, 2023 at 7:06 AM
SNSJSJ
I took my brake switch off and I put my multi tester on the pins of the brake switch and got no power at all.
Oct 8, 2023 at 9:53 AM
  • 110,248 POSTS
Were you checking the disconnected switch or the wiring connector from the vehicle? If it was the wiring from the vehicle, the power loss must be before the switch. This is where it will get difficult for me to help because I don't have a schematic to trace the wiring.
joe
Oct 8, 2023 at 11:47 AM
