No brake lights
253,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
MARK MCGAUGHY
I have turn signals and hazards. Brake lights don't work. Radio shorted out. Radio short causes dash lights to go out intermittently. Brake light issue started after radio shorted. Checked all can fuses.
Dec 11, 2019 at 4:40 PM
Good morning,
I attached a diagram for you to view. Check the fuse for the brake light switch for power with a test light or voltmeter. This is not a visual test, it is a power test.
Dec 11, 2019 at 5:47 PM
