No brake lights
150,000 MILES • 7.2L • V8 • 2WD • AUTOMATIC
VIPERKING75
  • 58 POSTS
Everything was working correctly, then randomly the brake lights stopped working. The brake switch has continuity. All the bulbs are good, the turn signals work. I have 12v going to the plug in the back, but nothing coming out, I tried to direct wire it and eliminate the plug but nothing changed, I checked the wiring harness in the bumper and can't find any bare spots and all circuits read the same resistance.
Sep 18, 2019 at 4:55 AM
94 TRANSAM
  • 680 POSTS
Hi and welcome back.
When you say you have 12 volts going into the plug in the back, I assume you mean the brake switch?
So if you have 12 volts going in what is the reading coming out? Is it 000 or is it showing some voltage with the brake applied?
Rich
Sep 19, 2019 at 1:26 PM
VIPERKING75
  • 58 POSTS
In the trunk there is a 4 wire plug that connects the wiring harness in the dash to a wiring harness behind the rear bumper, for all the lights. When I disconnect the plug and the brake switch is connected I get 12v between ground and each of the wires that goes to the brake lights, when I connect the plug together I lose voltage through the plug. I tried direct wiring it with no luck, the bulbs are all good, and the turn signals work all the way around. And the running lights all work as the should. I know the brake lights are basically the turn signals without the flash, and it doesn't make sense that I'm losing power, but only when the brake switch is applied .
Sep 19, 2019 at 1:37 PM
94 TRANSAM
  • 680 POSTS
Have you pulled the bulbs and checked the voltage in the socket using the socket ground?
I suspect there may be a bad connection somewhere which is why I asked what you were reading under load.
I would like you to plug everything in, apply the brake and test the voltage in the socket using the ground post in the socket. See what you get and then test it again, this time using the body as a ground. Let me know what you get.
Also you can test for a bad connection with a test light. Ground the light where the socket is grounded and test the socket. Does the test light light up normally or is it dim?
Here is a test light guide if you need it.
Rich
Sep 19, 2019 at 2:22 PM
VIPERKING75
  • 58 POSTS
I'll look into it, but if it was a bad connection why would the turn signals work?
Sep 19, 2019 at 2:24 PM
94 TRANSAM
  • 680 POSTS
The turn signals interrupt the brake circuit so it is likely that if the bulbs are flashing that your ground is ok. It is just a very common issue that I wanted to rule out. Once the brake signal leaves the brake switch it should go through the turn signal switch which will likely be your issue unless there is a brake relay in the circuit. The car is too old for me to pull up wiring diagrams.
Do you have a Chiltons on it with diagrams?
Rich
Sep 19, 2019 at 2:42 PM
VIPERKING75
  • 58 POSTS
I don't have a chiltons but I was able to find this a while back, it's not 100% the same but it 98% the same .
Sep 19, 2019 at 7:42 PM
94 TRANSAM
  • 680 POSTS
Okay, so I can't read the diagram you posted. Too small and fuzzy so I went looking and found this link...
http://www.mymopar.com/72to76_wiring.htm
In there I found the 2 diagrams uploaded below.
Praise the lord things have changed since then. These things are a nightmare. I had to study them for 30 mins just to get a grip and I still don't get it all.
Anyway, near as I can see, as I said the brake circuit comes out of the turn signal switch.
So, you say you have 12v going into the brown wire in the plug which I assume is the one on the bottom right of diagram "B" that I uploaded.
But you say you have nothing coming out of that plug. When you tested it did you unplug it or was it still plugged in when you got the 12v?
Rich
Sep 20, 2019 at 11:31 AM
VIPERKING75
  • 58 POSTS
I have 12v from black and violet and black and green, when not plugged in.
When plugged in I lose all voltage.
When each turn signal is applied I get a good strong flash and adequate voltage.
When the emergency flasher is on I get good voltage and good flashing on both the brown and violet and on all 4 bulbs.
It makes absolutely no sense to me as to why I'm losing voltage with the brakes but with nothing else, and only losing it when the plug is connected.
Sep 20, 2019 at 12:04 PM
94 TRANSAM
  • 680 POSTS
Can you unplug it and use a test light on the brown wire and see if you get a full glow on the light and then plug it in and do the same testing from each side of the plug.
Also when it is plugged in how many ohms are you reading across the plug on the brown?
Rich
Sep 20, 2019 at 12:40 PM
VIPERKING75
  • 58 POSTS
I have light on brown and violet, when unplugged. Last if I remember correctly I had about 1.6 or 2.6 ohms on both circuits, I can't remember exactly which, but I do remember they were both the same.
Sep 20, 2019 at 12:46 PM
94 TRANSAM
  • 680 POSTS
If you have 1.6 to 2.6 ohms across that plug then you have a bad connection.
This will be the tell. With the plug together, put one lead on the upstream side of the brown wire at the plug and the other lead on the positive lug in the brake light socket. How many ohms do you read?
Rich
Sep 20, 2019 at 1:20 PM
94 TRANSAM
  • 680 POSTS
You should have 000 ohms everywhere you check. That bulb should be a 1057 which is about a 1 ohm bulb. If you have a 1 ohm or more connection issue that would be enough to either light the bulb very dimly or not at all.
Rich
Sep 20, 2019 at 1:22 PM
VIPERKING75
  • 58 POSTS
Okay I misunderstood what you were wanting me to do, the ohm reading I took was of the brake light circuit.
I considered the plug to be the issue and completely eliminated it and tried direct wiring it
Sep 20, 2019 at 1:23 PM
94 TRANSAM
  • 680 POSTS
So you had 12 volts on the upstream side of the plug with it unplugged, correct?
And you have 0 volts at the socket with it plugged in?
And you are testing the brown wire for all of these as that is the brake light wire?
We are either losing info in the translation or something is missing because if the above info is correct the only possibility is a bad connection between that plug and the socket which is causing a voltage drop but all the info isn't adding up. It is in fact conflicting.
So here is what I need to help you.
Taking all these measurements can get hard to remember all the results, so I will itemize the tests I need you to do by number and description. Print this post out then take it to the car and write the results down for each number. Then come back and simply type just the number of the test and the result and I will compare that to this post.
1: Voltage reading on the upstream side of the plug.
2: Voltage reading on the down stream side of the plug.
3: Voltage reading from the upstream side of the plug to the socket.
4: Ohm reading from one side of the plug to the other side.
5: Ohm reading from the upstream side of the plug to the socket.
All of these tests should be done on the brown wire.
Rich
Sep 20, 2019 at 3:43 PM
94 TRANSAM
  • 680 POSTS
Also I should specify all socket tests should be to both sockets. Just give me an "L" and an "R" so I know which reading goes to which socket.
Thanx, Rich
Sep 20, 2019 at 3:48 PM
VIPERKING75
  • 58 POSTS
I can't answer all of those. I have eliminated the plug and direct wired it but as for.
1. (Wires disconnected) 12.6 v
2. (Wires connected) .06v
3. Please rephrase what you're asking for
4. 0
5. 0.1 L, LC, R, RC (c = center bulb)
Sep 20, 2019 at 3:57 PM
VIPERKING75
  • 58 POSTS
I think it maybe a ground issue, for some odd reason the license plate light started flashing with the turn signals.
Sep 20, 2019 at 3:59 PM
94 TRANSAM
  • 680 POSTS
Okay,
#3 was, I need you to measure the voltage from upstream side of the plug to the socket. So positive prob on the upstream side of the plug and the negative lead on the ground in the socket. If you don't get 12 volts you have a bad ground. Check in this manner on each socket.
My first thought was a ground issue and if your plate bulbs are flashing then that means you have feedback through those bulbs from another circuit seeking a ground. In other words you have a circuit going through the bulb to get a ground.
So next step is to Ohms check all your rear sockets to the body. Positive lead on the socket wall and negative lead to the body.
Write down what the reading is for each socket. Any of them that are not 000 ohms is a bad ground.
Trace the ground wire from any bad socket readings and then test the ground wire to the body like this...
You need a probe that can pierce a wire and then...
Set meter to ohms, pierce the ground wire 1 inch back from the connector with positive lead and put the negative lead on the connector. Any that don't read 000 is a bad connection from wire to connector. Need to cut wire, clean it up and put a new connector on it.
Also test connector its self to the body. Any that don't read 000 you need to pull the screw, clean connector, screw and metal where it connects. I use Permatex anit-sieze on my grounds cause it stops corrosion and it has a powdered copper base for conductivity.
Let me know what you find out.
Rich
Sep 21, 2019 at 3:53 AM
