no brake lights
146,000 MILES
ROBBIE36
Park Iights and turn signals work. No blown fuses. Replaced brake light switch. Still not wrking. Not sure what else to check. Any ideas? I am not real fimilar wit electrical problems. What other things GS can I check. Kind of hard to drive with no brake lights. I sure don't need any tickets. Help me please I have limited funds
May 27, 2013 at 2:17 AM
HMAC300
  • 48,601 POSTS
first check to see if you have power going to brake lights at back it could be a broken wire. then make sure ground is clean and tight. make sure bulbs are good and not made in China.
May 28, 2013 at 12:05 AM
HMAC300
  • 48,601 POSTS
forgot , it may also be your t/s multi function switch so check to see if power is going in and out of that
May 28, 2013 at 12:07 AM
