No boost. Low pickup
83,000 MILES
RAJIT PURUSHOTHAMAN
No power boost. Low pick up. VCds says EGR temp sensor voltage high, inlet manifold runner faulty, coolant temperature circuit faulty, and output Speed sensor of automatic transmission
Mar 17, 2017 at 3:05 PM
  • 55,711 POSTS
It sounds like you have more than one problem, first I would check the inlet runner diaphragm and linkage to see if they are all working, next I would test the catalytic converter. Here is the guide
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Is the car a turbo?
Please get back to me.
Best, Ken
Mar 22, 2017 at 7:39 AM
RAJIT PURUSHOTHAMAN
Thanks Ken for the Assistance. It is A VW touareg, 2008 model TDI with V6, 3000 cc engine .
The VCDS diagnostic software says 8 DTCs,
1) 005522 / P1592 Boost Preassure Sensor
2)001037 / P040D EGR Temperature sensor high
3) 008213/ P2015 Inlet manifold flap position
4) 008581 / P2185 Coolant Temp Sensor too high
5) 008448 / P2100 Throttle Actuator control Circuit open
6) 001027 / P0403 EGR Valve N18 Malfunction
7) 009254 / P2426 EGR Cooling Valve control circuit
8) 008449 / P2101 Throttle valve Actuator
I hope this helps. Thanks for your assistance. looking forward to hearing from you soon.
Regards
Rajit
Mar 22, 2017 at 12:06 PM
  • 55,711 POSTS
Please clear the codes and drive it, then read the codes again to see what comes up. We are looking to narrow the codes down by doing this.
Best, Ken
Mar 22, 2017 at 12:44 PM
RAJIT PURUSHOTHAMAN
Even after repeated dtc erases, the still persist. Replaced the exhaust temp sensor too. Still the turbo is not engaging.
Mar 23, 2017 at 1:06 PM
  • 31,937 POSTS
what is the code that is being set, erasing the code will not fix anything, if the turbo, or boost pressure regulator is faulty this will have to be looked at, but i need the code or codes first to see what is going on here.
Mar 23, 2017 at 10:00 PM
RAJIT PURUSHOTHAMAN
Here are the screen shots of vcds on the vw touareg. Kindly check and advise. I sincerely thank you in anticipation. I Look forward to hearing from you soon
Mar 24, 2017 at 3:27 AM
  • 55,711 POSTS
It sounds like you have a plugged catalytic converter follow this guide to check it out,
Best, Ken
Mar 24, 2017 at 3:50 AM
