Is there any thing else I can do to prevent freezing radiator
1997 FORD F-150
187,000 MILES • 4WD
CANDI SPRIGGS
Just got truck from friend passing away. no antifreeze in radiator only cap is on reserve. I tried to drain from underneath spout but it broke off in closed position slid metal ring clap off of hose line but it won't budge now it's getting dark outside and it's going to freeze. I left cap off for expanding water to go to. is there any thing else I can do to prevent freezing radiator and messing up engine? would one of those mechanics dual stand up lamp bring out enough heat if I place it over it?
Dec 15, 2019 at 1:20 PM
I would suggest changing the coolant so it has protection from freezing so you will not have to worry about this anymore. You can use a heat blanket to help keep it warm. The water will freeze at 20 degrees with volume.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
https://www.2carpros.com/articles/engine-coolant-59420607
May 7, 2021 at 4:09 AM
