No air from dash vents, floor, or defrost
2007 GMC YUKON
135,000 MILES
SARAHJOHN0908
When front dash vents are on there is little air coming out. We can feel some, but not much. Rear roof vent system works great.
May 21, 2022 at 6:59 AM
More than likely this is the mode door actuator has failed and you are getting a little bit of air due to the door being mostly closed but a little bit of air is able to get through.
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
Take a look a the info attached below and let me know if you have questions. However, I would suggest accessing the actuator and move the position of the air and see if the actuator moves.
Thanks
May 21, 2022 at 11:59 PM
SARAHJOHN0908
Thank you for the advice. However, we replaced the blower resistor, and everything works great now. Thanks again for the response.
May 22, 2022 at 8:18 AM
Thank you for that info. I didn't pick it up in the title of the post and focused more on the details you gave. The floor, defrost and vents are all different actuators.
So, this means the overall system had low air flow so of course the blower would not putting out much air.
I am sorry that I missed that but so glad that you found it and then came back to update us.
Thanks for using 2CarPros.
May 23, 2022 at 11:29 AM
