No air conditioning blows hot air
95,000 MILES • V6 • 2WD • AUTOMATIC
JESTER461
When I start car in seconds clicking sounds from rt dash. I tried the 3 button test at 75 degrees. Did not get read out.Just said Auto fan 75 degrees.
Is it the blend door actuator?
Jul 13, 2020 at 1:18 AM
Good morning,
I attached the procedure for the blend door replacement. It is under the dash and not bad to change.
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
You can get it at any parts store.
The noise is common when the gears fail inside.. There is a constant ticking and the blend door will not move.
REMOVAL
1. Remove left and right underpanel silencer/ ducts. Refer to Body and Frame/ Interior Trim/ Console/ Service and Repair. See: Console > Service and Repair
2. Remove two screws from actuator which are accessible from the right side of center stack.
3. Remove one screw from actuator on left side.
Blend Air Door Actuator
Blend Air Door Spline
4. Pull actuator straight down from shaft and disconnect electrical connection. Upon removal, note the shaft position of the actuator, because the shaft on this motor is keyed. When installing new actuator, its shaft must be positioned in the same location.
INSTALLATION
For installation, reverse the above procedures.
Jul 13, 2020 at 1:26 AM
JESTER461
Thanks. will work on it tonight when it's cooler.
Jul 13, 2020 at 2:12 AM
You are welcome.
Keep me updated.
Always glad to help.
Jul 13, 2020 at 3:08 AM
JESTER461
Do you mean I have to remove the whole lower console part of dash to get to the actuator?
It's a project car just go to it tonight.
Aug 20, 2020 at 7:01 AM
Yes. Just follow the instructions.
Keep me updated.
Aug 20, 2020 at 7:52 AM
