No air coming out of vents
2001 DODGE DAKOTA
200,000 MILES
JESSIE DEMOE
I turned my truck on and no air is coming out of the vents at all. Also, it is making a weird sound as if I can hear it changing gears when I turn the knob to change the type of fan. Weirdly enough five minutes later my radio turned off but then turned back on one minute later. Someone please help I do not know what it is and it is minus thirty degrees out and I need heat to drive.
Dec 12, 2016 at 12:58 AM
KOOLCADDY6
  • 60 POSTS
Check your fuse and relays.
Dec 12, 2016 at 1:48 AM
HMAC300
  • 48,601 POSTS
check for a vacuum leak or one of the motors with a line off/not working. also check for blown fuses and blend/recirculation doors not getting power or working. try pulling HVAC fuse with key on for sixty seconds may reset actuators as well.
Dec 12, 2016 at 1:54 AM
