No air blowing A/C or Heat?
2004 FORD ESCAPE
160,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
KCARPENTER69
Daughter has the vehicle listed above. No air blowing from vents. The blower motor and resistor have been changed with no luck. Could this be an actuator problem? If so, where is it located?
Jan 6, 2025 at 2:06 AM
  • 55,224 POSTS
When the system is on can you hear the blower motor running? If so, then yes, the actuators are not working and will cause this problem of the fan running but no air is coming out. I would look under the hood for a small plastic vacuum line that has broken.
Here is a guide to help you:
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Please let me know and upload an image if you find the broken line which should be near the firewall.
Jan 6, 2025 at 3:20 AM
KCARPENTER69
Yes I can hear the motor blowing. I will check after work. TYSM
Jan 6, 2025 at 3:36 AM
  • 55,224 POSTS
Yep, I bet you have a broken vacuum line under the hood very common.
Jan 7, 2025 at 2:25 AM
