No air
150,000 MILES • V6 • 2WD • AUTOMATIC
TONIE LYNN EDWARDS
My air started to work intermediately and no doesn't blow air at all. If it's jumped off the battery it will engage but not off its own wires. I've checked and tested everything I can think of and can't seem to figure this out. please help.
Jun 28, 2019 at 7:11 AM
  • 110,248 POSTS
Welcome to 2CarPros.
When you say it engages when you jump if from the battery, are you referring to the AC compressor? If so, have you tried recharging the system? Low Freon will prevent the compressor from engaging.
Take a look through this link to see if anything helps.
Here is a link that explains how to add freon.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Let me know if any of that helps.
Jun 29, 2019 at 2:22 PM
TONIE LYNN EDWARDS
No not the compressor, the blower fan.
Jun 29, 2019 at 3:12 PM
  • 110,248 POSTS
Welcome back:
Okay. When you said in and out, I suspected it was the compressor. Does the blower motor work on any speed?
I really don't know what all was checked, so bear with me. The first picture I added below is a flow chart to inspect everything with the blower motor being inoperative. That is the last thing I need you to follow.
First, there is a 40 amp fuse in the under hood fuse box that needs checked. See picture 2.
Next, have you checked the fan relay? See picture 3. It's the fuse/relay panel in the vehicle.
If you checked those things, there is power to them and they are good, then you have to follow the flow chart in picture 1.
Here are a few links to help with testing electrical components:
If the blower motor works on high only, suspect a bad blower motor resister. Here are the directions for replacement:
__________________________________________________
BLOWER MOTOR RESISTOR REPLACEMENT
Blower Motor Resistor Replacement
Removal Procedure
pic 4
1. Remove the right side insulator/closeout panel.
2. Disconnect the electrical connector from the blower motor resistor.
pic 5
3. Remove the blower motor resistor screws from the HVAC module.
4. Remove the blower motor resistor from the HVAC module.
Installation Procedure
pic 6
1. Install the blower motor resistor to the HVAC module.
Notice: Refer to Fastener Notice.
2. Install the blower motor resistor screws to the HVAC module.
Tighten the screws to 1 N.m (9 lb in).
3. Connect the electrical connector to the blower motor resistor.
4. Install the right side insulator/closeout panel.
Jun 30, 2019 at 11:59 AM
