no acceleration while in drive or reverse
598,777 MILES • 4.6L • V8 • FWD • AUTOMATIC
JAMOE64
complete tune up ! runs better on cold starte 4-5 mins in to running idol stallout asoon as you put in drive
Apr 1, 2014 at 3:53 AM
JDL
  • 16,098 POSTS
High mileage vehicles can have this issue. Not much load on the engine till you put it in gear. Check cylinder compression, if really low on all cylinders, You may have a tough time getting it to run correctly.
You can check idle air and check for applicable trouble codes. You can check your rpm specs.
Apr 1, 2014 at 4:52 AM
