No acceleration, vibration.
63,000 MILES
DARRELL57
  • 5 POSTS
Started the car. Begain backing up. Car shudders and rough idling. Put in park Idles seems fine. Put in drive Idles rough won't accelerate over 20-30mph. Will not move in reverse now.
May 2, 2013 at 9:26 PM
DARRELL57
  • 5 POSTS
Okay. Really Strange. Just went to check it again. Everything seems normal but the service light is on.
May 2, 2013 at 9:40 PM
KHLOW2008
  • 41,812 POSTS
You need to retrieve the trouble code to find out what is causing the problem.
Most parts stores provides such services but do not rreplae anything first. Let us know the EXACT trouble code and we shall see what needs to be done.
May 2, 2013 at 11:03 PM
DARRELL57
  • 5 POSTS
Went to Autozone. Code was a p1241. They couldn't find a listing for a Mitsubishi. Hunted online and found out it is a torgue monitor? I drove nearly 60 miles(I live out in the stix). No problems. Wonder if maybe a gliche in computer and when I restarted it reset? I don't know. Just really confused right now. I assumed it had to do with trans. but the guy at that place said it actually isn't part of the transmission. So any feedback would be helpful. Thanks
May 3, 2013 at 2:16 AM
KHLOW2008
  • 41,812 POSTS
P1241 = Torque Monitor.
TECHNICAL DESCRIPTION
Compares the actual torque signal computed from a mass air flow sensor signal with the driver demand torque signal computed from an accelerator pedal position sensor signal.
TROUBLESHOOTING HINTS (The most likely causes for this code to be set are:)
Throttle actuator control motor failed.
Connector damage.
Harness damage.
Intake system vacuum leak.
There is some trash around mass airflow sensor.
ECM failed
Check the wire connections etc arounf the MAF and throttle actuator.
When a problem is detected, the would trigger the MIL and go into limp mode. After restarting, the ECM would check through again and if it finds nothing wrong, the MIL would not illuminate and engine would work normally.
Since the problem did not recur, it is intermittent and you need not worry about it until it reappears.
May 3, 2013 at 4:30 AM
DARRELL57
  • 5 POSTS
Thanks for your time and the information. I'll check these out. And definitely save this info in case the problem arises again. Thank You once again
May 3, 2013 at 4:56 AM
KHLOW2008
  • 41,812 POSTS
You're welcome
Have a great weekend.
May 4, 2013 at 2:07 AM
SULTAN0
Hi, same thing happened to me on Friday! What was the problem in your car?
Thanks
Jan 25, 2016 at 5:59 AM
DARRELL57
  • 5 POSTS
Never found out what caused the problem. It never did it again. I traded in the car last November. Sorry I can't be more help.
Jan 25, 2016 at 9:30 PM
SULTAN0
Ok thanks
Jan 26, 2016 at 2:54 AM
KHLOW2008
  • 41,812 POSTS
Time to close this question.
Jul 7, 2016 at 2:56 PM
