No acceleration
455,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
GPASS
I have the truck listed above, 22R, 2bbl, four speed.Original owner. Over the last 150,000 or so miles it has had a few issues that I promptly repaired. The usual maintenance stuff: alternator, water pump etc. Then I replaced the head about 75,000 miles ago. No problems it ran great until a few weeks ago.
Starts and idles fine, revs fine all is normal except when I put it in gear and head out there is no acceleration ! It just goes flat.
I have done the following:
New fuel filter.
New fuel pump.
New air filter.
New distributor and vacuum advance.
Set timing.
New BVSV (I broke the tip off so I replaced it).
Replaced vacuum lines with new hose.
New rebuilt carb, bench tested and dialed in.
Adjusted valves.
Compression front cylinder to rear 180, 185, 190, 180.
Still starts and idles great until you drive it, step on the gas and it just goes flat with no acceleration at all.
Does anyone have any thoughts on this?
Mar 31, 2018 at 6:54 AM
WRENCHTECH
  • 20,760 POSTS
It would be a good idea to have the back-pressure in the exhaust tested to check for a plugged catalytic converter. It should have no more than 1 PSI measured in front of the catalytic converter.
Mar 31, 2018 at 8:29 AM
GPASS
Thanks. I finally got some time to check it out and that seems to be ok. I may try another vacuum advance. Perhaps the one that I purchased is defective. NAPA said they would swap me out.
Apr 9, 2018 at 6:10 AM
STEVE W.
  • 15,411 POSTS
Will it slowly accelerate if you slowly give it throttle or nothing? Have you checked to be sure it isn't something like a jammed brake or similar? Might be a good idea to verify it will roll freely in neutral.
You can test the advance with a timing light, plus you say it revs OK out of gear.
Apr 11, 2018 at 8:02 AM
