No power from engine ?
192,000 MILES • 4.0L • V8 • 4WD • AUTOMATIC
JEROME GODWIN
Truck is fine until it warms up and then act's like it wants to cut off and does not accelerate.
Sep 20, 2016 at 3:35 PM
SEVAG P
  • 405 POSTS
hello,
sounds like fuel pump problem, as a first step read fault codes send to us to narrow down our problem.
check our link below how to check fault codes.
check our link how to check fuel pump.
install outside fuel pressure gauge test drive when the pressure drops means you need fuel pump.
check the table and diagrams below how to check fuel pressure specific to your engine.
let us know if you need more help.
thank you.
Jan 29, 2021 at 9:04 PM
