No acceleration after replacing the EGR valve?
100,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
RANDYDUNN10
  • 29 POSTS
EGR valve had a hole blown in the side, replaced the EGR valve now the car won’t accelerate.
Jan 27, 2023 at 11:18 PM
  • 110,248 POSTS
When you replaced the EGR, was a new gasket used? Also, there is a vacuum supply to the EGR. Is that connected? If you start the engine and remove the vacuum hose, is there a vacuum source present?
See pic below.
Jan 28, 2023 at 2:24 PM
RANDYDUNN10
  • 29 POSTS
New gasket with EGR valve. No strong vacuum present.
Jan 28, 2023 at 11:09 PM
  • 110,248 POSTS
Follow the vacuum hose to see if it is cracked, damaged in any or disconnected.
Let me know what you find.
Jan 29, 2023 at 7:02 AM
RANDYDUNN10
  • 29 POSTS
Should there be strong vacuum?
Jan 29, 2023 at 7:22 AM
RANDYDUNN10
  • 29 POSTS
What causes the side to blow out on an EGR valve?
Jan 29, 2023 at 7:23 AM
  • 110,248 POSTS
As far as the vacuum, it is controlled by an electronic vacuum regulator valve. So vacuum changes based on conditions. It will fully actuate the EGR once the vehicle is warm, under a moderate load, and the PCM determines it can open
The thing is this. If there is no power, it sounds like the EGR is open at all times. We need a vacuum for it to open, so let's try something.
I attached a pic of the EGR vacuum regulator below. Allow that to remain connected, but I want you to remove the vacuum supply at the EGR itself. At the end of the vacuum hose you disconnected, plug it with a screw or something that will prevent vacuum loss.
Test drive it and see if it runs any differently. If it does, the regulator may be faulty
See pic below.
Jan 30, 2023 at 7:34 AM
RANDYDUNN10
  • 29 POSTS
No pictures, I’ll be heading back to the shop tomorrow and I’ll let you know what I find.
Jan 30, 2023 at 7:46 AM
  • 110,248 POSTS
Wow. I'm getting old. LOL Sorry about that. I did attach it this time. If you can, before taking it in, try what I suggested. It will only take a couple of minutes.
See pic below.
Jan 30, 2023 at 11:40 AM
RANDYDUNN10
  • 29 POSTS
Would this cause the valve to explode?
Jan 30, 2023 at 7:14 PM
RANDYDUNN10
  • 29 POSTS
Okay, tried what you recommended. No change.
Jan 31, 2023 at 4:26 AM
  • 110,248 POSTS
Okay, I was thinking something was causing full vacuum at all times and the valve was being held open. Were you able to take it in today?
As far as the damage, the only thing I could think of is if it cracked, damaged, or removed and not installed correctly. Do you have a pic of it that I could see?
Jan 31, 2023 at 10:43 AM
RANDYDUNN10
  • 29 POSTS
I have not taken it to a shop. I was hoping we could figure it out.
Jan 31, 2023 at 10:55 AM
RANDYDUNN10
  • 29 POSTS
The EGR valve that exploded was the pen part.
Jan 31, 2023 at 10:56 AM
  • 110,248 POSTS
That's an odd one. Do you remember any backfiring? Also, could you have a plugged catalytic converter?
Jan 31, 2023 at 11:03 AM
RANDYDUNN10
  • 29 POSTS
Could a bad catalytic converter throw a check engine light?
Feb 1, 2023 at 5:12 AM
  • 110,248 POSTS
If the converter was bad, it should set a code such as a P0420. However, anything is possible.
Also, since we had an EGR that was blown out, that could have been an escape for the exhaust if the converter was an issue. Once you installed the EGR with a new one, the leak was repaired as well. A plugged converter will certainly cause a power loss. Take a look through this link. Also, as a simple test, remove the upstream oxygen sensor (pre-cat) and see if you get the power back.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Feb 1, 2023 at 5:58 AM
RANDYDUNN10
  • 29 POSTS
Sent it to a shop today. I’ll let you know what they say.
Feb 1, 2023 at 7:14 AM
